I?ve got a new-to-me ?93 90hp Evinrude with the tach not working and the battery not charging. Done a lot of searching and found this fine forum? and have read / searched it over as well, and done some of the tests (now I?m dangerous). Through all this, I?ve learned that it?s very likely I?ve got a fried regulator / rectifier which is a water cooled unit (part # 584204). So, I?m looking to replace it which brought on several more questions about removing the flywheel (also researched).
In another post from years ago here (Re: 85 Evinrude 115hp, Rectifier / Regulator Question No Purple Wire), it was eluded to that I may be able to ?cut the wires? and wire in a ?standard? rectifier. Is this an option? If so, I have a bunch of questions:
1) What rectifier would I order to wire in? I?ve concluded I have the 3/9 amp stator (#583586) as I have P/T/T.
2) Which wires would be cut to splice in the replacement / where would it need to go in regard to the wiring?
3) Is it possible to differentiate / confirm that the regulator is OK and rectifier is not? How to?
Adding a ?standard? rectifier would really make the job much easier, cheaper, and eliminate the poor design which seems to fail often (and possible cause a fire). By the way, I just replaced the water pump which was probably the root of the failure from the previous owner.
4) I also noticed discussions on the stator being fried as a result of the regulator / rectifier failing. Is there a way to check / verify this prior to digging in?
5) If I do have to ?dig in?, after flywheel removal is it self explanatory as to replacing the original regulator assembly? Any ?adjustments? to be concerned with?
Thanks in advance for any information to any of the many questions I am asking. I?ve got a Clymers manual but it?s very weak for all this (it was weak for the water pump as well!).
