1977Evinrude
Thread starter- Joined
- May 16, 2007
- 5
I had my boat on the lake last weekend I was running it at 3/4ths throttle and all of a sudden the rpms started dropping until the motor stopped. I tried starting the motor, and the started engaged, but the flywheel was stuck. I couldn't manually turn the flywheel. I let it sit for a little while and I was able to manually turn the flywheel and the motor started again. I was able to put the boat into drive, but after about 100 yards it did the same thing and died again. I pulled the boat out of the water and pulled the spark plugs to see if there was water in the cylinders. It looked like there could possibly have been a little on the threads so I put a little oil in the cylinders and the motor turned over and started. Anyone have similiar problems or have any idea what could be the issue?
