setting carb
mobleybj
Does anyone know the carb settings for a 9.6 sea king
model vwb27009a?
Thanks Brian
steelespike
Re: setting carb
Motor is a 70 initial setting of idle mixture screw is one turn out from gently
bottomed.final setting is made warm running in gear.Clock wise to richen.End of float opposite pivot should be 1/64 below float bowl surface when inverted.
mobleybj
Re: setting carb
Ok thanks I will try it i have gotten it to run but I have to have the throttle turned just far enough that the starter will engage.
Thanks Brian
