Re: flunked compression test
There are also places that sell rebuilt powerheads for around 1200.00 if you want to just bolt something on that is allready done for you. I would still consider doing it yourself if you are at all mechanically inclined, it really is easy, take your time, take lots of pictures, and question the forums.
Yes irollint, it is an easy motor to work on, mine was a 86 125, complete tear down, re-bore and rebuild, never worked on a motor before, and it runs great now. also, if it is only the one cylinder, and the cylinder doesn't look scored bad you can pull the piston out and replace it without cracking the case open. pull the head to check your head gasket first, then check the problemed cylinder wall. Mine was a broken ring that got cought up between the wall and the piston, so I had to bore and hone.
