The choke plate isn't opening on my 3.0 merc. I can get the engine to start if I remove the air cleaner and stick a screwdriver in the carb opening to hold the choke plate open. After 20 seconds I can pull the screwdriver out and the boat continues to run just fine. The plate isn't stuck and the choke spring isn't broke. The temperature when I do this is mid 40's. The boat is normally only used if its more than 70 degrees outside.
