Valv
Thread starter- Joined
- Jun 12, 2001
- 391
I just bought this used boat, hasn't been run since 2005. 1974 Mercruiser 120hp motor oil is very clean, I assume it has been winterized and never used then.
Motor cranks fine but I have no spark.
-I disconnected dist. center post, grounded it, and no spark at crank.
-I opened dist, points close by specs
-When ignition is on if I open points with a screwdriver they spark.
-Coil has 12v power at + post and 12v power at - post.
Any other possible issue ?
There is an external condenser which is disconnected and wire is hanging loose, where does it go on the coil ?
Thanks for any help
Thanks for any help
