If you read my earlier post about the throttle replacement, you might have seen this, but I wanted to post it as a new issue:
Trim Button seems to raise engine/drive all the way up.
I left the Purple/White wire disconnected from the controller as no one seemed to be able to tell me what its for. Of course today I found it thanks to one of Don's posts. (i've really got to print out these manuals instead of sections :redface: )
http://www.boatfix.com/merc/Servmanl/11/11a5r5x.pdf
On page 5A-52 it lists the Purple/White as going to the trim limit switch. So, if I left this unconnected, the TRIM control will bypass the Trim Limit Switch? Is that a fair statement?
Since I left the Puple/White wire disconnected, where should I have hooked it up so that it would work. Attached is a wiring diagram of my controller to hook up the trim & tilt switch but I can't figure out where this purple wire would go? I assume it would wire in with the Blue (Trim Up) to the Trim Up button of the controller?
Edit #1:
Uploaded the wiring schematic of the trim. Now, notice how the trim wires have a Purple/White that comes from the Trim Limit Switch.(Attach #2). The Controller (Attach #1) doesnt have this wire. The TRIM buttons have GRN,BLUE, RED. The TILT button has GRN, WHT, PURPLE - It says purple from TILT goes to Power (which should be RED to power the button itself, correct?)
Thoughts?
Edit #1:
Thoughts?
