cbrady@ardmorecity.com
Thread starter- Joined
- May 23, 2007
- 5
I have a 1989 Johnson 140HP V4 on a 1990 invader fish & ski. Has always started perfectly, almost. The first start of the day will determine if it will work well. Generally only needs to crank a few seconds to start. Once it has started once it will start fine all day with just a mere bump of the starter. However if it decides not to start right away it might not start @ all. Took it to a local boat shop & he said is was unusual. When I took it in I had just ran the bettery down trying to start it to no avail. He said no fire & he would check it out. As he worked on it he said that it would erratically fire on different cylinders @ different times & then it just all started working fine again. He said he couldn't fix a problem if he couldn't see it not working. Started it last night & it worked fine. Now I am gun shy about taking it out. Like I said great motor 95% of the time, but the other 5% will leave you stranded. I have worked on car & truck motors but boat motors are new territory. Any good suggestions would be greatly appreciated. Thanks,
Oh, By the way, The only modification from factory I have had on the boat it to remove the VRO & I manually mix my own oil/gas ratio so I KNOW that it is getting oil. This was performed @ the same local boat shop.
Thanks again,
CEB III
Thanks again,
CEB III
