Gasket
Bruce53
Need some advice here. I am about to tie the new outdrive to the old transom plate. I have the gasket. Do I use a sealer or put it together dry. If sealer, do I use rtv or the non-hardening sealer. Do I use it on both sides or just one. Can/should I use a silicon grease on both sides of the gasket? I have been the habit of sealing only one side with rtv on some gaskets on parts that I expect to separate and reclose like valve covers. Any suggestions would be most appreciated....
Re: Gasket
It goes on Dry Bruce.........
I use a spot of Grease to hold the O-rings in place.......
