toyotaspeed90
Thread starter- Joined
- May 23, 2007
- 12
the engine is a 4.3L Mercruiser.... it's a GM engine.... has Alpha 1 stamped on the carb cover
the boat it's in is a 1990 20' Bayliner capri....
I just 'purchased' this boat a few weeks ago... it was annually Winterized and Summerized by a local Marine Shop. The family owned it since new in 1990.
I called the shop who did the work and they gave the following reports:
-Bellows are showing wear
-Gimbal bearing is 'growling' (though, i've had it running and I can't hear anything I shouldn't.... and I'm also a little skeptical of the shop as the family I got the boat from is extremely well off and never did the work to the boat themselves... so the shop could have been over-exaggerating the problems to get work orders)
-Poor water pumping while idling but fine at running speed
I've had the boat on the water and I've been watching the gauge like a hawk whenever we stop. It seems to run great (quite quick for it's size), turns great, makes no noises, and no other mechanical issues.
However.... I'm no dummy when it comes to engines.... I am ASE certified and have previously been a mechanic at a local shop and currently work at a car parts store.... so I understand the possible dangers if it does overheat.
Now for the end of this rediculously long thread....
I do not believe it has a freshwater cooling system as it has a tank with coolant in it.... is this a correct assumption?
Is there any sort of pump that might be causing an overheating issue at idle other than the waterpump bolted to the block (because in a car i've never heard of an waterpump having problems with cooling at idle but no problems at running speed....unless it has an underdriver pulley on it which this does not).
Lastly, is the waterpump comparable to the GM 4.3 waterpumps found in s10's, jimmy's, blazers, and astro vans? It looks to be almost the same, but I'd rather have the parts before I start a waterpump swap and be sure I have the right one.
Thanks!
Thanks!
