Okay, I have two questions I need your help on. I have a 1997 225 Evinrude that I just fired up after a long winters nap. Changed the plugs w/ new champions (I gapped to 35 but understand they should be at 30 which I will correct this evening).
1) My engine idles fine, runs from 1500rpm-up fine, but kind of runs a bit rough from let's say 1000-1500rpms...just a bit of shaking. Doesnt want to stall, just doesnt feel as smooth. Idles fine in gear at about 650 rpms. What is causing this?
2) I need to change my prop--what size nut holds the prop on? I thought it was a 1" nut or? 13/16 was too small.
I really appreciate your help!
