Re: 58 35hp sea horse vacuum cut-out switch bypass
The mercury switch/wire from the throttle gears does two things:
1. It completes the ground circuit for the starter solenoid. That is to prevent starting with the throttle set too high. By grounding it, you defeated it's purpose and now it will start with a wide-open throttle (in gear) and run over the dock ....or person.
2. It completes the ground circuit for the vacuum cut-out switch. That is so that the switch is grounded and operates only at slow throttle settings. By grounding it, you defeated it's purpose and now the vacuum cut-out switch can operate at any speed, especially at "cruise throttle" settings when there is a high vacuum.
However, go back and read my previous comment about bad coils. You are wasting your time till you establish their condition, good or cracked.
http://i155.photobucket.com/albums/s311/frankr_photos/crackedCoils.jpg?t=1180089362
