I have a MY2000 90Hp Mercury Tracker that is fouling sparkplugs. The engine does not get used often and it is likely that the bad fuel has caused fueling problems.
Two weeks ago I removed the carburetors, took them appart and cleaned them. Surprisingly they were all very clean except for the #4 carb, it was slighty dirty. I removed all of old fuel and put in fresh along with carburetor cleaner. The engine seemed to be running well and no longer had the stumble when going to wide open throttle. However, it continued to run rough with minumum throttle with the drive engaged. Over this last weekend while out on the lake I was running the engine at 5000RPM and the motor cut back to ~3800 rpm. I took it back home and pulled the plugs. Number 2 and 4 were black / fouled out.
What are the potential causes of this? The floats did not seem to be adjustable, the fueling circuits are controlled by jets, so not much to adjust there. Could something be wrong with the choke? Thank you very much for any troubleshooting advice!
