I have a 78 Mercruiser 165. Changed the outdrive lube to discover it was milky although it did not appear to be low. Still got a little more the an quart out of it. Anyhow, trying to pressure test the outdrive just to be sure. I don't have a manual so I've been piecing together a procedure from what I can find online. Here's what I've done so far..
1) drained the out drive and left it on the boat
2) hooked up the pressure tester to the bottom drain hole and filled to 5psi for 10min - no pressure change
3) increased to 10psi for 10 minutes - no change
4) increased to 13 psi for 3hrs. the first 2.5hrs had no change at the end I saw a 1/2 psi drop, but only after I handled the guage/pump, so I'm suspicious if it leaked from the gague/pump itself.
5) increased to 14 psi for 10 minutes - no change
So now I'm seeking advice.. does this sound like an ok procedure? Did it pass? If it passed, why did I have milky oil?
Thanks for the help!
