Re: Merc 7.5HP outboard, no cooling water
The impeller blades are a bit tall so that they will press firmly against the upper pump plate, and the bottom of the pump cartridge.
The difference in impellers is not the height of the rubber blades, but the Inner Diameter (i.d.) of the impeller hole. There are 2 different sizes; you wouldn't be able to fit the smaller-i.d. impeller on the larger-o.d. driveshaft, but if you had the smaller-o.d. driveshaft, it'd be possible to put the larger-i.d. impeller on and I suppose it'd be real sloppy.
The impeller should fit snugly around the driveshaft, if there's a lot of slop it's the wrong one. I'd definitely pull the lower unit down and remove the top of the pump. Don't take the impeller out yet; turn the driveshaft and make sure the impeller is spinning. Check with a strong lite to see if there's any gap between the impeller i.d. and the driveshaft.
I'm not sure how much water you can actually force up the intake screen on the lower unit, you likely can't get a perfect seal there, and the water has to get past the pump before going into the powerhead.
The way to be absolutely sure there are no obstructions in the upper parts of the motor is to apply water to the copper pickup tube (with the lower unit removed, as described earlier). If water goes up the tube, out the telltale and down the middle of the "exhaust tower" (center section), you should get good flow with the lower unit installed, provided the pump is in good shape and the water tube is properly inserted/sealed into the pump body.
The fact that you're getting hot air out the telltale means little or no water is getting to the powerhead, and exhaust exiting down the center section is being blown up into the water discharge passages of the block and out the telltale.
Anyway, best to yank 'er down, check out the pump, flow water thru the motor, see what ya got. BTW if the pump plate or pump insert (cartridge) have deep ridges worn into them, you won't get much pumping. The ribs on the impeller seal against the top and bottom to make the pump more efficient. Time to put all the parts under close scrutiny; you may find a combination of worn parts is adding up to no pumping.
Keep Us Posted...........ed
