Re: maybe cam problem please help
I'm still betting that the cam timing is off by a tooth and the no start is caused by the extra backpressure. My friend had a camaro one time that intermittently would not start, even on starting fluid. It had good spark, but slightly low compression even though it was a brand new motor. We finally decided that the cam was too aggressive and bleeding off too much combustion pressure, so he decided to replace it. Lo and behold, when he got the timing cover off and aligned the marks in preparation for removal, he discovered the cam was off by a tooth. He adjusted the timing and put it back together, compression was up and he hasn't had a problem with it since. Course. I've been wrong before.
Stan
