55'Fleetwin7.5
Thread starter- Joined
- May 29, 2007
- 241
I was given some bad advice from my local marine parts dealer.... I am a new "old motor" enthusiast. I was trying to replace my ignition parts when I came to a barrier... The flywheel. I removed the nut and washer then tried to lift it. I took my rubber mallet and tapped around the perimeter in a circle... NOTHING. I do not own a gear puller, so I called the local shop. The counter person asked the shop staff and they told me to replace the nut a few turns and then strike down in the center with a small ball pean hammer. Viola' off it came. After reading a bit on this forum, I am getting the idea that I really screwed up when I did this. The motor seems to run ok... Is this a terminal blunder or a "don't do that again" blunder? PS I have purchased a gear puller.
