shear pin??
niss_det
i have a 63 omc 40 hp and i am having a hard time finding shear pins and prop cones.. i dont wanna go out without having extra.
Re: shear pin??
They were so common (at one time) and used for so many years, they should be easy to find. Try a discount marine store, then try a Johnnyrude dealer.
If you get stuck, you could likely make your own out of the correct diameter brass or stainless. My '58 Fat-Fifty used a 5/16" Stainless pin. I don't think it would shear, without tearing up the brass hub on the prop. The 40HP models used a thinner pin(1/4" or 3/16"), and it could have been brass.
Re: shear pin??
laingsoutboards.com has them both call them great to work with
BoatBuoy
Re: shear pin??
Correct shear pin, part no. 304575 available from your JohnnyRude dealer, $1.85.
