Havana Daydreamin
- Joined
- May 31, 2007
- 7
While performing maintainance on a 1987 1.6 OMC seadrive, there was a fuel leak noticed at the fuel primer solenoid. It would only leak on start up when the key was pushed in to activate the fuel primer solenoid. It would shoot a stream of fuel from the red lever located on the fuel primer solenoid. The red lever was found to have a split down the side of it. The part number listed in the OMC original parts catalog is #397909 . That is for the whole assembly. The solenoid works properly it just has the leak do to the split. The question is can you just buy the red lever and related components? Is there a kit to repair the parts that are damaged or a rebuild kit? I do not want to buy the whole assembly only if I have to. If there is any of these options to repair it, does any one have any part numbers or where to buy these components. Any help is appreciated.
