I have an Apha 1 gen 1 stern drive coupled to a Merc 5.7. The outdrive shifts into forward and reverse gears fine, but binds when trying to take it out of gear. It binds when taking out of forward and reverse. I tried adjusting the shift cables as per Merc manual without any success. I have disconnected the throttle/shift lever to isolate the problem and it appears to be in the stern drive unit. The shift cable doesn't bind, it feels like there is something grabbing in the stern drive. If I turn the engine off and restart it will start in neutral and everything is fine until I try to shift out of gear again. When the engine is off it shifts fine into and oout of gear it inly happens when the engine is running. I recently purchased this boat with this problem and thought it was just a matter of " A little adjustment". This is not a problem that just suddenly showed up. I suspect it has been there awhile. Thank you in advance for any help that can be provided.
