Pikeslammer
- Joined
- Aug 24, 2002
- 9
Last year before I bought a manual to replace the pump in my 1957 evinrude fisherman 5.5 hp, ser#5514-08182, I tried to change it thinking the lower unit came apart in the same fashion a forty horse or similar motor would. Remove the lower unit bolts and unhook the shift rod connector. After I got a manual I discovered the error I made. Not removing the powerhead and unhooking the shift rod from the shifter. Since then I have tore it down changed the pump and put it together, had it jump out of forward gear, tore it down again and tried to straighten the shift rod I bent(Before the days of a manual), put it together have it move in forward for awhile and jump back into neutral again, tore it down once more to see what the heck happened, to discover the lower unit gears now have slight damage due to the motor not being fully engaged. I have put it back together for now, but have refused to touch it again till I get a new shift rod and possibly new gears for the lower unit.
Can anyone share their ideas as where to find a shift rod and some things I could do or try to adjust get the lower unit to fully engage? Is there an adjustment somewhere? Could there be any other causes for this motor to jump out of forward gear. Other useful info I noticed: The shift handle does not seem to be in the right position when in neutral and reverse. When in reverse the motor runs fine. The motor has never had a problem until I tried to change the pump the first time. When first put in forward gear it seems to engage then when you accelerate it jumps out of gear. The shift rod was difficult to move by hand.
Any and all suggestions or questions would be gratefully appreciated. This is the best motor I have ever owned and well worth repairing. I don't need to be told how dumb it was to try repairing this without the book, trust me I have been beating my head against the wall since I realized I messed up.
I look forward to your comments.
Best wishes, Alex Birch
