loss of speed
I am new to the thread but not to boating. I have a 2004 Ebbtide 190 campione with the 4.3 v6 (carburated). This last sunday was my first time out on the lake this summer. When I first started out I had absolutly no power. Then, as I was driving I realized "spark plug wires" I stopped the boat look to see if a wire had come off. Sure enough, one had fallen off. I secured it back on the plug, and checked the rest. Started the boat back up, reached 42mph WOT with trim up. Last year I would get about 52-53mph WOT. I plan on changing all the plugs, rotor cap and bug along with a little seafoam in the carb. What else can I do to get it back up to speed? What could be wrong with it? I dont know what the RPM's were either, I forgot to write it down. Any suggestions?
Let me rewind here a second. Two years ago, when the lake was low I hit some rocks going around 5mph. Chewed up the prop, and took a little piece out of the skeg. Filed down the skeg and replaced the prop, the rubber insert looked fine.
Don S
Re: loss of speed
Would that V6 be Merc or Volvo?
QC
Re: loss of speed
How are you measuring your speed and did you get there after the prop/skeg fix?
Re: loss of speed
The prop/skeg incident happened 2 years ago. When it happened I immediatly drove it slowly back to the ramp and loaded it.
The decrease of power happened just this last sunday(june 3rd)
Re: loss of speed
Funny you say that, last year instead of adding stabil,I completly drained the fuel tank, because of the gas/ethanol blend. Eventhough I drained it water still could have accumulated in the gas tank? I couldnt hear any type of stutter after I attached the spark plug wire.
