72 115hp merc stops like a kill switch
Alphabiatch
Just got a 72 Cheetah w/ 115hp Mercury (also 1972). The idle, throttle and spark advance were all in need of adjustment. Got those pretty much dialed in but when driving at high speeds for about 1 minute the motor just stops, suddenly, like a kill switch. Could this be some sort of automatic shut-off? As low as this boat sits in the water the last thing I need is a sudden stop. oh, it starts right back up and isnt overheating.
Clams Canino
Re: 72 115hp merc stops like a kill switch
Got a voltmeter on it? That unregulated charging system can rise the 12v system up to 17+v - This can cause your ignition to do strange things. If that's the problem - drive with your lights on and the radio etc to use up the extra current available.
If that's not the problem - you have a thermal intermittant fault in the switchbox or trigger - likely switchbox. There is no auto shut-off except for the little mercury tilt-kill switch on the port side of the switchbox.
-W
Alphabiatch
So it wouldnt have anything top do with the fuel lines (people keep telling me to check for air leaks, dirty, etc.) or the rev limiter?
Alpha, There is no rev limiter on that motor. You might try pumping the fuel primer bulb at high speed to see if you have a weak fuel pump. if that doesn't help, it may be the ignition issue that Clams cited.
croSSed
I would be really surprised if this were a fuel issue. The fact that it suddenly just quits points to an ignition/electronic issue. A fuel problem would not do that. Even if the flow of fuel were suddenly and completely cut off, it would stumble along for a few seconds before complete shut down.
TG
