reelfishin
- Joined
- Mar 19, 2007
- 3,050
I just bought a boat with the above motor, it's a short shaft 18 HP with only the recoil starter. It starts fairly easily but is super hard to pull. It feels as if I am going to yank it off the transom when I pull start it. It starts and runs good but it feels like it's going to snap the rope each time. It has the over the flywheel style starter and the motor has 140 psi per cylinder. It's a low hours motor that runs strong, it's just super hard to pull. I have pull started my larger motors with no problem, but this one is a real bear.
It's my only older motor. I can't imagine that this is the way it should be, I nearly have to put my foot on the motor to keep it down when starting it. I have a later 25 hp that runs good and don't pull nearly as hard.
Can I convert this to electric start? Was there a compression release or different style pull starter for these? The motor is not 'tight" it just feels like I don't have enough mechanical advantage over the compression. My other manual start motors all have the low mounted style recoil. The compression didn't seem too high to me and the motor spins free with the plugs out. It came to me on an older boat that sat for years, but it started right up and I have used it several times with no running problems. I had it running for about 4 hours straight the last time out and it did great, and it restarts with only one pull, but still takes all you have to hold onto the handle and spin it over.
Was this just normal for this motor?
As far as I know this is all original, and nothing looks changed or out of place. I bought it from a guy that said he bought it new and rarely used it, it was collecting dust in his garage for years. The boat was slightly newer than the motor but the motor is a good match for the boat. I took the recoil all apart and lubed all moving parts with no change in the feel or pull needed to crank the motor. It does have a ring gear for a starte on it already and it don't feel all that hard to spin by hand if I grab and turn the flywheel with the hood off.
