exploding mercruiser
xltier
i took a mid 90s bow rider out for a spin.it has a carbureted 4.3 v6.center bolt valve covers.it wasnt running too good when all of a sudden there was a bang.i turned to see a cloud of smoke.when i checked under the cover i could see that the vale covers were blown outwards and pushed the gaskets rite out.could this have been gas in the oil or something like that.
Don S
Re: exploding mercruiser
Could have been.
Ayuh,.......
Gasoline Fumes are about the Only Thing that Could do that...........
Probably Sputtering alot,.... Running Lean,......
All the Gas was going into the Base, instaed of the Carb.......
Is it a Mechanical Fuel Pump,..??...
xltier
Ayuh,.......
ill have to check,someelse is pulling it apart.i was just a passenger this trip.trying to see y it wouldnt plane off.ive seen auto engines so full of gas that they liquid lock and not blow.must of been fummy!!!!kinda gets your attention.
It Can't Liquid Lock if it's going Directly to the Base,+ Not thru the Intake.........
That's why I asked about the Fuel Pump......
Don S
Unlike an automotive engine, the mechanical fuel pumps also have a hose on them going to the carb. If the diaphram leaks, it will put fuel into the engine oil, but it will also dumps raw gas into the carb instead of out on the road like a car does. If this keeps up long enough you have a lot of extra gas in the oil and a real rich condition while running. One backfire with all that extra gas and.......... well, you know the rest of the story.
f_inscreenname
I hate to say it but you were lucky it was inside of the motor then inside the bilge.
