My new 55 Minnkota Terrova arrived and after mounting on the boat, I find when the propeller is turning, it makes a significant rattle which grows louder with higher RPMs. Even with the prop off. this is all out of the water. I found that when I loosened the thru-bolts a bit the rattle got lower and lower until it reached "normal". I know the rattle was WAY above normal. Is it OK to loosen the thru-bolts a half turn or so?
bakerlh
bakerlh
