beerfilter
- Joined
- May 11, 2007
- 305
I have just bought a used Gamefisher(made by Force)1992,9.9hp kicker.
The good:
Lower unit lube is perfect.
Has good spark.
Good compression indicated from the pull resistance,sound(I'll confirm tomorrow with my gauge...).
Powerhead seems to be in very good condition.
Plugs are a normal color with no fouling.
The bad:
Cover is cracked(no big deal,a little resin and cloth...).
Tilt lock is broken/missing parts(?).
Reverse is non-existant.
The ugly:
The majority of the shift linkage parts are missing from the motor.
Sears doesn't have many of them in stock.
I cant seem to get reverse by manually shifting the main linkage rod.
My question(YES,FINALLY....):
Will the shift linkage parts from a 1996 Gamefisher/Force 15hp be a direct replacement?
My motor's model# 225.581995
Candidate donor's model# 225.581508
I am not pressed for time,as I have a 9.9 Merc for this old Appleby,just couldn't pass up this deal.
TIA
The good:
Has good spark.
The bad:
The ugly:
TIA
