1973 70 hp evinrude no spark
Re: 1973 70 hp evinrude no spark
Welcome to i boats. history on the motor, did this just start? is motor new to you? dirty grounds or connections, all connections, stator or power pack. don't think both coils would go at the same time. here are some test, 6 pages, find you engine. http://www.boatpartstore.com/page28.asp
woodpac
no is not new to me but it is a on going thing it
really sounds like a loose or dirty connection, could be ignition switch, kill wires.
woodpac
i read the pages 27-29 but i have no cap or points it is m# 70573b s#jooo4262
BoatBuoy
Your engine is a '75, not a '73. Use the link TD supplied but try page 29.
woodpac
i have no power to power pack key is on
BoatBuoy
It doesn't need power to the power pak. It doesn't even need a battery. But it does need one to spin the starter motor, or hand crank it. It's simply a glorified magneto that uses a trigger coil and CD circuit to deliver a hotter spark.
woodpac
:confused:just about to giveup and go to shop still no spark
woodpac
:confused:is there a easy way to test power pack
BoatBuoy
woodpac, you have to do what you have to do. The CD ignitions like yours that did away with points and condenser, although some would say they're more dependable, are much harder to diagnose. It takes some electrical test equipment that most folks don't have. I don't. On my last one, I got lucky. I suspected the powerpack and replaced it. That fixed it, but powerpacks can be an expensive experiment.
One last thing you can try - disconnect the main wiring harness at the large rubber plug on the engine. Then jump the solenoid and see if you have spark. If you do then there's a problem in the kill circuit to the controller. If you don't, I'm out of ideas. BTW, if you start it like this, you'll have to choke it with the manual choke, or pull the fuel line loose to get it to stop.
