Had a strange problem recently with my ?86 Force 125. Was out on the lake running at WOT for about 5 mins when the motor seized - or so I thought. Was at full throttle one second, then a clunk noise, and it stopped. Could not crank the engine and could not turn the flywheel using a wrench on the bolt on the top. Prop turned freely when trying to crank/turn flywheel. Don?t think we hit anything as there was no damage to the skeg/prop/lower unit. Was using last year's gas but had stabilized it and oil mix was fine as far as I knew.
I figured that the motor was shot. Hadn?t checked for coolant flow when taking boat out as I usually do, and thought I had overheated it and warped it until it locked up.
About eight hours later, my son tried cranking it and it had miraculously freed itself up. Cranked it for a few secs and it fired up. Let it idle at the dock for about 10 mins, and was pumping water just fine. Took it out for a test run and was fine at low rpm, but made some unusual noises at higher RPM (sounded like a scraping noise). Shut it down for fear of more damage.
Got it in the driveway and removed the lower unit drain plug ? lots of water in the lower unit. No metal shavings visible in the cylinders from the spark plug holes.
So what I thought was a powerhead problem looks like it might be a lower unit problem instead (or both).
Is there anything that could happen to a lower unit that would stop a motor cold from full throttle? I would think that if something locked up in the lower unit, 125HP at full throttle would shear something and the motor would keep going.
