Re: Fluid Dynamics
Re: Fluid Dynamics
Dabalone, it all goes back to what I said in the beginning before we got into an arguement over how hydraulics work. I said it depends on why it is hard to steer now. If there are excessive bends and twists in the cable that is a very valid reason for hydraulics. As said, the fluid doesn't care how many turns it has to go through. Second good reason is steering torque. I am telling you that hydraulic won't eliminate that, but the no feedback feature built into hydraulic steering helms will make it stay where it was when you stopped turning the wheel. That way you don't have to constantly fight it. I am sure you know what I am talking about here.
Sorry, I wasn't going to say any more about this, but can't help myself. Whether jacking a car, using a crowbar or steering a boat, there is a trade-off of some kind. There is a direct relationship between the displacement of the helm pump versus the displacement of the hydraulic cylinder that steers the motor. If the helm and cylinder were the same displacement it would be just as hard to turn the steering wheel as it would be to try to steer the motor by grabbing it by hand. Make the displacement ratios 2 to 1 and it would be half as hard. Make it 3:1 and it would be a third. The bottom line as far as steering goes is the number of turns of the wheel that it takes to steer hardover to hardover. The more turns the easier the steering. People start to complain if it is much over 4 turns because it takes too much wheel spinning to dock the boat. But even 6 or more is often seen on big boats. That same ratio effect is found in cable steering only is is through gears in the helm. Still 3 turns or thereabouts. Try it. The same principle is found in the car jack. You have a small piston in the pump and a much larger one raising the car. You move the little one a whole bunch of strokes in order to move the big one one stroke.
