newbiebassman
- Joined
- Jun 13, 2007
- 3
Feeling 'tupid here.
How do I "unlock" the trailering lock holding the engine up. This is a 90 HP Johnson, ~1985? on a fiberglass bass boat.
I found the switch that operates a hydraulic piston that raises & lowers the engine to the towing position, but there is also a small latch, that appears to keep weight off the piston while being trailered. I can't figure out how to disengage this latch, so the hydraulics can lower the motor. I don't want to loose my casting fingers.
Thanks,
Thanks,
