Painting with Perfection
Tail_Gunner
I used Prime Kote and sprayed it on with good result's, the primer is easy to shoot and i would not do it any other way looking back
Ok so far so good, now lots' fo sanding with 220 grit sand paper about 8 hours to get the flat finish im looking for
Tail_Gunner
Re: Painting with Perfection
Now disater strike's, i have sprayed Bright Sides before and the reuslts were quite good. Perfection is another story, after trying to differnt sprayer's i never was able to get the paint to atomize in a way that i could lay down a light and uniform coat......... This is best left to pro's who deal with this paint day in and out, at least for me that is....
This might look good ....it wasnt
That's using 1200 wet paper known as color sanding, i dont know if you can see the vertical waving in these pic's that is sagging, not really apparent when done but trying to smooth out the finish with sand paper, it became very apparent using a buffing compound i was able to bring back some of the paint............:mad: but between the wife and kid's it was back to the drawing board.......:eek:
Ohh big thing here for me anyway's, noitce the rub rail is now off the boat, the reason is Perfection dries incredibly hard and when taking off the tape it may add hours to the job that is taking a knife or blade and getting small stips off.........kinda like one glued down the tape to the boat......it's not fun at all....
Tail_Gunner
After maybe 15-20 hours of sanding again using 220 grit i was finally down to a flat finsih i needed any more grit and you tend to just cut it all off the boat and that you do not want to do.
This paint was rolled only, not tipping i used foam roller's i picked up a Fred Meryer's a kinda of target like company i tried to use some West Marine stuff but the foam just fell apart which makes for BS in your paint.
This time i applied 3 coat's very light coat's and sanded very lighty on each coat, the trick is to take your time and let the paint work "flow" that is. Ive metioned no tipping there was none, after mixing up the paint i let it set for 15 mins letting the air bubbles dissapte and then just rolled her out maybe 6' at a time, it goes qucik then i would go back and reroll her again for good measure (sag's) and making sure most of tha paint had been used up out of the roller.
Later on i will post the type of roller's i used, never thought to save them at the time, after a litte buffing i donot believe there will be any imperfections in that paint at all, but rolling it in a garage there is some tiny bit's of dust... so the higher the heat the faster the drying time and less contamination..;)
drewpster
Great job TG! Question Time,
Did the roller you used leave stipple as you applied it?
After applying the paint did you buff the paint to that finish, or did it dry with that great shine?
Did you color sand between coats or did you color sand before buffing?
Tail_Gunner
Yes there was a very small amount of stippling after passing with the foam roller, i'd go down a 6' patch thoughly one time and when the roller had exhausted all the paint back id go to the beginning and do another swat. It leveled out perfectly each time after about 5 mins, but you cannot go back and do a spot say 15 mins later that will not work.
That finish is the final cure, no sanding or buffing at all, i am very tempted to do a little buffing ( small dust here and there) but i think not, at least for now. I am quite satisfied, thanks RP i still have some gold to go in there it should be pleasing to the eye........... at least mine i hope...:cool:
Opp's no color sanding at all, 220 grit very lightly just roughing it up or breaking down any perfections between coating's.
JJB
The boat looks great ! Did you use perfection paint below the waterline ? I asking because I need to paint my transom gray and cant find a paint to use in gray other then topside paints . I trailer also ! Thanks JJB
Boomyal
Looks very racey Tail Gunner. Just hope you don't think that will give you any kind of advantage!:p
BTW, did your masking tape hold a clean line?
Tail_Gunner
Dunno why that link wouldnt work, Yes for 99.95 percent only one spot very minimal
tallcanadian
great job tailgunner. very professional. i used the brightsides with good results. i just hope mine stays on when i put it in the water..lol.
fishingdan
Perfection seems to be designed for application by roll and tip method. I know others that have had trouble spraying it. Personally, I think the results using roll and tip are outstanding and I wouldn't do it any other way. The key is to work in small areas and apply thin coats.
Excellent work.
Tail_Gunner
silverline1
That looks great, you said you used a roller? If you don't mind could you list what you used? roller types, paint, and primer. Would be greatly appreciated.
Tail_Gunner
http://www.kpg-industrial.com/products/quick_solutions_premium_minirollers/
0-78435-90488-0690192240Woven Mini Cover, Large Diameter4 in.61 lbs.
http://www.kpg-industrial.com/wheretobuy/ga/
Applied Industrial Technologies 877-279-2799 Automotive Fasteners 800-632-0340 Avera Industrial Supply 706-547-2489 Bearing Distributors, Inc. 216-642-9100 Blackburn Manufacturing Company 800-552-3524 EIS, Inc. 800-949-9992 Fastenal 507-454-5374 Grainger, Inc. 888-361-8649 Hagemeyer North America 800-752-0007 Industrial Distribution Group 404-949-2100 Interline Brands 904-384-6530 Kaman Industrial Technologies 888-235-3550 McJunkin Corporation 304-348-5211 McMaster-Carr 630-600-3600 Motion Industries 800-526-9328 MSC Industrial Supply Co. 800-645-7270 ORS Nasco 800-678-6577 Precision Industries 800-373-7777 Samson Industrial Supply 918-583-1791 Turner Supply Company 251-438-5581 United Rentals 800-877-3687 Utility Safeguard 877-899-7233 White Cap Construction Supply 800-944-8322
Fred Meyer's in my locality
Interlux Prime-Kote sprayed
Interlux Perfection rolled only no tipping
Interlux 2316 spraying solvent
Mixed at no more that 10% by volume (2316 to Perfection)
Rolled in 70 degree heat
I guess i should have taken a video of the paint leveling but then again watching paint dry is another adventure......;) It does level practice on a mirror and see for yourself..
alaska_av8r
Next question.....How did you paint the bottom, did you remove it from trailer and how....I sit here scratching my head on that one....
Tail_Gunner
The painting you see was done on top of Gel Coat, no bottom thank the god's .............. your on yur own there my freind............:D
peacekeeper6
i am painting my boat completely white, would that paint work as an all purpose paint for all over? if it sprayed well i would like to use it as i can spray better than roll. thanx! i also trailer and fresh water wash down after each run.rarely do i leave my boat at the base dock for an early morning run.
Tail_Gunner
Perfection is a very high quality paint, not just in apperance but in durabiltiy also. There is no need to spray with it......... i know that goes against the norm, but you do NOT have to go that route.
Actually rolling it out create's less taping and masking, less overspray err none. After doing two boat's now the system i have come up with is so simple a 10yr old could do it.
1 I use no thinner's or reducer's, they only create bubbling or stippeling and delay drying time futher allowing dust or bug's to get in the paint
2. Start the paintiing in 70 degree heat, the paint does not setup as fast and high temps can speed it up and i like to take my time.
3.To apply the paint i use 4" or 6" inch foam roller's, i have found that if i roll about 8'x4' i can go back and using a fresh roller i can roll out any bubble's or stippling and runs that are present( Use a very light pressure here very and be patient). It leaves a very very fine nap on the paint and level's out as flat as glass...time is key here do not let the time go beyond 5 mins to flatten out imperfections or stippling and once your done and she setup's that's it leave it
4.Do not try to get the paint to cover in one or two coat's it will take 3 or maybe even 4, thin coat's will not run and if you go back with 300 grit with in 24 hour's in 70-80 degree heat it's still soft enough that it sand's very easy scuff the surface so you can apply the next coat. For myself i found that sandiing before the paint really harden's make's the job much eaiser.
5. After 2 coat's look very closely for minute run's or imperfection and carefully sand them out, your now setting yourself up for the final finish the first two are just base coat's make every attempt to not sand thourgh the paint, and if you do... so what, it only take's about a hour to sand paint it again but when your done and if you take your time it's a great look and guess what........your all done with wax and buffer's keeping that gel looking good....;)
As to priming some say you have to some say ya dont on fiberglass, i have done both and the jury is still out there, but if you do and if you can i'd use Primekote the stuff is as hard as nail's and near the water line i would highly recomend it, but you cannot use it over any paint that is or was a single part urethane..........Ohh now that stuff spray it does not roll well and it is very hard to sand.....very
peacekeeper6
so in theory, if i was trying to make the boat white could i just use the primer as the paint?
