drewpster
- Joined
- Oct 17, 2006
- 2,059
My old boat had an overboard dump type head. I replaced the old head with a macerator head and installed a holding tank. I had planned to remove the thru-hull fitting and glass up the hole. However at this piont I am leaning toward simply replacing the thru-hull with a stainless one blocking the hole and forgoing the glass work. (my plate is full with other projects)
I was hoping someone knows of a block off fitting made for this rather than using a standard thru-hull. If not, you think I cut the barb off the fitting and have a plate welded to the fitting on the inside blocking it off?
Any other ideas?
Any other ideas?
