Re: 1975 johnson 115 power tilt & trim
The motor still spins and it sounds like it is binding up. i was told by someone else to take the small rams apart to check seals. does this sound write? i think i checked the check valve. is it below the motor with a big flat head screw to access? how do i access these valves?
thanks Jon
if the motor becomes noticeably labored then what is probably happening is ....
the motor and cylinders are functioning fine. But the pump is not opening the release valve in down direction. So your cylinders can go up but never down because there is no way for the bottom fluid to escape. If the cylinder was bad then either fluid would come squirting out top or the engine would bleed down rapidly.
do you have a calco or a prestolite?
Assumming prestolite my guess is that you need a new oring on your shuttle valve. Pumps are relatively complicated little devices. It could be any number of things but my odds-on favorite would be shuttle valve oring.
