i was given this motor and it did run great ...its a 90hp with the vro...it used to idle nice but no more..the first sign of trouble is when it would start up no problem and idle all day...it would run at the slow speeds through channels...once it was running at higher rpm...no tach so i have no numbers..it would run fine for close to 20 minutes then just completly die out...i'd wait a minute it would start up no problem..away i'd go and then again after 15 minutes running on plane at crusing speed it would die out again...i tried changing the fuel filter today but it almost seems worse..the b ulb is never really soft plus its one of those water seperaters and there is always fuel in the bottom clear part..it does not really wanna idle and i'd have to start it every time with the throtte lever up almost all the way....put it down quick then jam it into gear to stop from stalling...its strange because its hard to duplicate. any ideas!!!!!!!!
