1977 Johnson 40 hp Outboard - loses power, bogs down
RdNkWm
I am having trouble with my 1977 Johnson 40 hp outboard. Ok, no snickering out there, I am female, but try to do and repair most things myself, but this one has me at a disadvantage. While driving my bass boat, the engine starts fine, takes off fine, full throttle and all that, but then, all of a sudden, it loses power. It is acting like it's not getting enough gas. The bulb is tight and stays tight even after it stalls. It will restart with throttle. Once I move the lever back down and try to reengage the engine it will die. If I am using the throttle, it will idle. Yesterday, I took the boat back out to see if I could get it to run, I had to have it full throttle several times, just to keep it running. I eventually was able to engage the engine, but even with it open full tilt, boat was going really slow. Also, when I was just sitting there letting it idle, I thought maybe I had some bad gas in the lines, it was emitting a white smoke from the engine. After reloading the boat and bringing it home, I started investigating. The first thing I went to was the carb cover. Took it off, it look pretty much clean, then I took out the fuel filter and found what looked like sand in it. Ok, I went and bought a new one, but after reading this forum yesterday and today, everything indicates that I should rebuild the carb. I had the card replaced 2 years ago. Boat is originally from Texas and after my Uncle died, it sat for awhile until I got my hands on it. Never had any problems with it (9 years) until now. I guess my questions would be this. Should I rebuild the card? Should I empty the gas out, clean the tank and replace gas? And, is there anything else you might be able to help target before I put it back in the water. Also, yesterday, before I launched it, I put the muffs and hose on it and it was running fine, thats why I decided to take it for a ride. After a few minutes out on the water though, it started to bog down really bad. Suggestions please.
lexkyboater
Re: 1977 Johnson 40 hp Outboard - loses power, bogs down
I have a 71 Johnson 9.5 HP and it was doing the exact same thing. Ended up being fuel pump. The acid test for checking fuel pump though is to see if it will run while you are pumping the fuel bulb by hand, in essence you are doing the job of the fuel pump. If it runs when you are pumping the bulb, you can almost guarantee that's a fuel pump problem - it sure fixed mine.
Other issues might be a fuel line that's split and letting air into the line - and that's a much cheaper fix. If you have splits in the line, you might want to go ahead and replace that first anyway. HTH, Steve
RdNkWm
Thanks LexyKyBoater. I will check both tomorrow and let you know what happens.
wooddoc
I am having a similar problem with my 1978 40hp Johnson. It will crank and run great for about 200 yards and then it will go dead or idle slow. You can pump the bulb when it starts to shut down and it will pick back up and run for another 200 yards or so. Any suggestions? Thanks Wooddoc
HybridMX6
Suggestion would be to start a new thread for your particular problem, especially since this thread is almost 2 years old and I doubt it will catch much attention.
