engineerlutz
Thread starter- Joined
- Jun 19, 2007
- 7
Hello, I've read this forum for some time now while working on this old Clinton Sea King that my friend asked me to fix.
I should start by saying the engine I?m working on is a 1977-78 Clinton Sea King Model KTV52307 Clinton Mod K753. I've had a tough time finding the specific manual for this engine but with the combination of other Sea King manuals I have been able to get most of the basic maintenance done.
When I received the engine it had been sitting outside on the boat exposed to the elements and not run for about 3 years. My friend had complained that it was really hard to pull to start but seemed to run fine once it was started.
When I got it into the garage, the shifter was stuck solid along with most of the bolts. After carefully taking off the cover and the pull start I immediately took off the carburetor and found it to be dry and clean. I put it back on and began to look at the lower unit.
The lower unit on this model must be very unique because there seems to be no way to get it off. I couldn?t find a way to disengage the coupling for drive. No access holes, nothing. Only screw holes i could find were the ones at the exhaust port and the recessed bolt on the leading edge just in front of the water intake. I drained the lube from the lower unit because it looked like it needed a change (it was dark brown and was the consistency of peanut butter). Replaced it with new lower unit gear oil. I didn't bother to take apart the gear housing and the prop.
I managed to unstuck the shifter with weeks of wd-40 and a mallet. I?m not sure if it engages the prop, and I fear it doesn?t. When I turn the starter by hand the prop doesn?t turn. My only hope stems from when I tried to start the motor, I noticed it turned the prop to a different position.
About this time I got some new gas and mixed it 1:50 with outboard oil (before i read to use chainsaw oil). With the engine primed and put back together I gave it a few cranks.
This thing about pulled my arm out of it's socket. took about 10 pulls and it wanted to start and even burped out some exhaust but the pull to start the thing is so much I couldn?t do more than 10 tries. I was also worried about the stress on the parts with that much force.
I took off the starter again and noticed that one of the teeth that grab the power head was worn. It has about a 1/4 inch gouge in the tooth. There are 4 teeth, 2 engage to turn the power head.
Now i put it to you guys to help me out.
What can i do to ease the pulling force on the pull starter so I don?t damage the starter and my arm?
Is there any other maintenance i should conduct on the engine?
What is the secret to getting into the lower unit to check the impeller (I?m fairly certain it has one)?
Is there a way to make sure the drive rod actually turns the prop without starting the engine?
This engine wants to run, I can hear it, I just need to make it easier to start so I can fiddle with the carburetor adjustments.
Any advice and comments are appreciated. Thank you for your help in advance. If any of you would like to see some pictures, i can provide them.
SL
SL
