I Have An 94' Johnson 225 Ocean Runner, That Won't Run Over 2500 Rpm. Have Changed Water Pump (entire Kit), Thermos. Engine Was Visually Running Hot Before Replacing Wp Kit, But Does Not Appear To Be Now. Good Stream From Tattle Tale. Pretty Sure That This The Slow System, Causing Engine To Lose Rpm @ Exactly 2500. Unplugged Temp Switches, Runs Fine. Tested Blocking Diode With Ohm Meter, Ok. Tested Temp Switches, Port Side Switch Has Tan/green Wire And White/black Wire, Clymer Says To Check Ohms Between Switch Housing And Tan Green, Results Switch Closed. Checked Switch Further By Checking Ohms Between The Two Wires While Cool, Switch Open. Heated Switch In H2o Switch Closed.
Am I On The Right Track, Is My Switch Good Or Bad. Any Other Ideas, Help Would Be Greatly Appreciated. Thank You!!
