I have a 1980 120 mercruiser. I changed the impeller and am having problems putting the lower unit back on. Everything seems to line up right but the shift shaft does not seem to be lining properly. I have locked the lower unit in forward gear and put the boat in forward gear like the manual says but it still doesn't seem to line. The upper shift shaft is kind of loose. I can move it up or down, the position of the upper shaft does not seem to matter. I can get the main drive shaft engaged but only 3/4 of an inch from the two matting up. Holding it is the shift shaft. This is the first that I have tried to do, any help would be appreciated.
