mudweiser
- Joined
- Jun 21, 2007
- 115
Just bought a 77 Ranger 1750 with a 1977 Johnson 115 V-4. The engine starts and idles nicely. When in gear, at low RPM it runs nice. Problem is about 3,500 rpm, it will bog out until it stalls. It will do this over and over unless you accelerate very slowly (sometimes thats not even the cure, i will have to run the engine on high idle and before the engine revs fully down to idle i need to hit full acceleration, then wait for it to clean out). Once you can move the throttle to full without stalling, it has a miss. This will continue for about 10 seconds, then the engine "cleans out" and top end is fine. It will do this when ever you hit the 3,500 RPM, over and over. Since i bought the boat, i have removed and cleaned out the fuel tank. Filled with fresh gas. (The tank was clean when removed). Rebuilt and cleaned the fuel pump. New fuel lines, primer ball, connections. Carbs removed, cleaned and rebuilt with new needles/seats gaskets etc... New plugs and plug wire caps (the old ones didn't clip on the plugs very tight. Any ideas what it could be?
