25 hp pumping water
rooster1
no one in mercury room maybe someone here will help just bought a used 25 hp merc and you have to rev it up to get it to start pumping water does it have a thermostat or something? i just have it in a barrell of water like i said you have to put it in gear and rev it up for it to start pumping?
Walker
Re: 25 hp pumping water
A used motor with no history needs a new waterpump for starters.
rooster1
ty how much installed a 25 hp 86 model merc in good shape bought at yard sale today for 500 like i said when it starts pumping it keeps on just seems to me it should start when the motor does im new at boating
kenmyfam
Do not know this motor and i am sure someone will answer in the correct area for you shortly. If the motor is used and you do not know its history then you need to change the impeller and thermostats if it has them and also the lower oil and possibly plugs. Do a compression check as well and you should be ready to roll if all is well.
Should really keep this in the Mercury forum though.
rooster1
thanks kenmyfam got it running runs perfect did have to get new plugs and run some seafoam through it
kenmyfam
Glad it worked out for you but you should still change the cooling stuff so you know it will most likely not let you down unexpectedly.
