5.0l Mercruiser,Reverse wont work :( help!
jayjames
the engine is in a 1999 searay 190, and whenever we go to engage reverse, the engine cuts out. after a while out on the water sometimes it works fine. we recently had a problem with corroded electrics near the throttle, but we have fixed that (we think) and it still does it. any one ever had this problem,
thanks
jason
180shabah
Re: 5.0l Mercruiser,Reverse wont work :( help!
Lotsa people have had this kind of problem, your lower shift cable has probably stretched. You can try readjusting it, and it may get you through the rest of the season, but if it is bad it will need to be replaced.
jayjames
yes, its an alpha
thanks
jayjames
k thanks,i`ll get
my mate who knows a bit more about it to take a look.
