RATHSLABBER
Thread starter- Joined
- Jun 9, 2007
- 8
My water wasn't spitting out like it had been so the mechanic said I needed to replace the thermostat and he did. Ran it 4-5 times and it had running reel good peed great. This weekend I noticed the water was barely coming out then stopped coming out of the bypass hose on top of the block. There was water still coming out of the back of the engine with the exhaust but I limped it back into the dock, the motor still ran good but just didn't want to push it. I cleaned fish then went to start the motor nothing. The starter would barely engage. I thought I may have seized the motor up. Well all that was was a loose battery connection, problem 1 solved.
But, would that loose battery connecting make the thermostat stop working and not pump water. I thought the impeller ran off the engine. I need help in solving this problem. Bad thermostat? or do I need a new impeller? Thanks for your response.
