Starts, won't idle
Speedo
Merc 260 with a rochester 4 barrel. Starts but won't run under 1400rpm. Mechanic suggested a reman carb, I suggested he rebuild the existing carb. Any idea how much $ it would cost to rebuild a 1982 Rochester 4 barrel?
TIA
Manipulator
Re: Starts, won't idle
Buy the kit online...it's about 16-20 bucks and do it yourself. So with shipping it probably $25.
Coors
But the Gunk carb cleaner to soak it in ain't cheap, but you have to use it.
Speedo
I am afraid my cigar would burst everything into flames.
I would prefer a professional do the rebuild, bench time would be what, 2 hours max?
Coors
yep; needs to soak for hours, but he can bee working on other boats, meanwhile.
Speedo
at $75 an hour should I budget for 2 hours plus the kit?
Speedo
Anyone know the shop time for a carb rebuild? Mechanic pulled it last week and it still isn't back up and running.
Way More than it's Worth.........
Way Less that That,.......
Maybe an Hour to remove it,+ tear it down,.... Drop it into the tank,.... let it soak a Day,.... Another couple Hours, tops, to reassemble, install,+ Tweek it......
You're a Few Days over schedule right Now...........
For a couple Hundred Bucks,... you could have bought an Edlebrock,+ been boating that afternoon..........
Speedo
I would have preferred to do it that way but my boat is docked at a marina about 2 hours away from my house and tools. I prefer not to buy a trailer but these local mechanics are REALLY slow at getting anything done.
Rebuild was installed, still no idle, any thoughts?
Coors
Tell the tech to fix it?
Or maybe more problems; ignition, etc
