Low Unit Problem-evinrude
shipwreck
i am trying to remove lower unit on my 1967 evinrude sport 60
model 60733
The lower unit comes loose and hangs it will not disconnect, the manual dose not cover this problem. the lower unit has a extension gearcase the sit on top of it then the power head.
I removed all the bolts wear the extension meets the exhaust case, which lets the extension gear case and lower unit hang but it will not drop out.
also the engine is in netrual .
Should the engine be in forward?
Will this let drop down?
Re: Low Unit Problem-evinrude
isn't that electric shift. did you disconnect the wire. and get it thru the housing. if not electric, did you disconnect the shift linkage.
F_R
That is mechanical shift. Remove the inspection plate about half way down the midsection, then remove the second one behind it. Inside, you will find the brass shift rod connector. Remove the lower bolt from it, then you can drop the gearcase down.
When you put it back together, use a flashlight to look in there and make sure the notch in the shift rod is perfectly aligned with the screw hole before inserting the bolt. If it is not exactly aligned, it will wipe the threads off the screw every time. Then it will fall out 5 miles from the dock.
shipwreck
you guys rule , i got her dropped....no it was electric shift
the manual i have stinks
thanks o bunch
brass shift rod connector is hosed somebody did a number on it , the screw are stripped i need to look at the connectors threads to see if they are.
any idea where to get part or can be repaired?
shift shaft is bend a little will that cause a problem?
and oil is leaking for the rod hole
F_R
Get parts from any evinrude or johnson dealer. You mean the shift rod coming out of the gearcase is bent? It is supposed to be. That's so it will clear the water pump. If it is leaking oil around it, the seal is shot. It is just a fat o-ring, but you have to take the gearcase apart to replace it.
shipwreck
A just finished taking the water water pump off , it has black oil in the house too.
Also a white crust in the housing, what is that?
I am really not happy with the clymer shop manual ..i bought today.
sleco manual for my other motor is way better then this.
Anyway...i bought i lower unit seal kit , it is on order.
Question , if i remove the lower gear case assembly to get to seal is there any thing else i should do? Any special tools need?
The oil was milk white / when changed/ no shavings
