springer07
Thread starter- Joined
- Jun 19, 2007
- 5
Will the thunderbolt ignition box cause the engine to run sluggish and take a long time to build rpm's. I have done everything else,plugs,wires,coil,carb cleaned and complety gone through,new wires from key switch to coil, new positive and ground wires. also checked the big connector to make sure there was not any pushed pins, rebuilt alternator and new voltage regulator. The other thing I notice is that when I use the power trim button on the throttle handle that it makes the engine break up, it is like it looses 500 rpm's.
please help, Jim
please help, Jim
