ut_freak23
Thread starter- Joined
- Jun 11, 2007
- 15
I have a 1985 Johnson 115 SeaHorse. This motor has been stored for about 6 years. The motor is very clean. It was stored properly. Recently the boat was taken out of storage and this is what we have so far. We replaced the spark plugs, drained old fuel in tanks, new fuel lines, new fuel filter, and changed lower unit oil. The motor started after a couple of cranks on the water muffs. The water pump indicator shot water. We had no fuel leaks or water leaks. The motor idle very smooth no smoke. When the boat was taken out to the lake it ran like a champ for about 45 minutes. This is a bowfishing rig so we killed to motor to fish some. When we started back up it fired off no problem and idled great. When we started to head back to the dock the boat would rev up to speed but then die out or idle down. When the boat would die it would start right back up and idle but on full throttle the boat would reach high rpm then die again. We waited about a week and the boat did the exact same thing starts idles runs for about 45 min to 1 hour then we cant get the boat to run wide open. Any help in this area would be appreciated.
Thank You
Josh
Thank You
Josh
