I took off my lower unit from my 97 Force 120 and rebuilt the water pump. I followed the manual and shifted into forward before removing. However, after re-installing the lower unit and cranking the prop turns only in a forward motion whether I shift to neutral or reverse. The splines on the shifter shaft appear to be aligning but its hard to know for sure once you start to tighten the bolts. Is there a trick to getting the shifter s plines to marry with the adapteror do you have to readjust the shift linkage everytime you pull off the lower unit?
thanks!
thanks!
