thumpar
Thread starter- Joined
- Jun 21, 2007
- 6,138
So I am changing to pertronix ignition and coil. There were 2 wires on the + side of the coil. I removed them and traced them back and found 1 goes to the back of the starter and assume this is from the ballast resistor. The other wire goes to the front of the engine just under the valve cover to what I am assuming is the temp sensor.
This seems really odd to me. So now do I take the wire from the back of the starter and feed it straight battery power and put the wire that goes to that sensor back where it was on the old coil (which doesn't sound right to me) or do I connect the 2 wires that where on the coil together, put the wire back onto the back of the starter and run a new wire from ignition + to the coil?
TIA
Edit: Forgot to mention this is an '83 merc 120.
TIA
