Zeusdafreak1
Thread starter- Joined
- Jun 28, 2006
- 62
I have discovered an oil leak. Its leaking from right behind the main pulley from on the botton side. It looks as though it is coming from the timing cover. There is a small sensor(that you can plug in to to service I assume) just above this. I removed the plug and it has a red o-ring on it. I could then tell it was NOT coming from this plug deal. I reinstalled it and wiped it all down and it is definitely coming from what I am assuming is the timing cover.
It looks like there is plenty of room to do this job myself if I were sure of the steps. After removing the belt and a hose and a couple of simple brackets then there is a water pump that must come off. Then the main pulley which I assume I will need a special tool for that I will have to go buy. This should expose this "cover" that is leaking from the bottom. It is held on with about 5 3/8 bolts because I tried to tighten the bottom two but it didn't do any good. Still leaked. The "cover" stops ablut 1 inch above where the oil pan bolts up so the oil pan doesn't look like it will come into play.
Is ther an online service manual I could buy and download to assist me in the job? Is this job difficult enough to really need one?
Am I looking at this job right. Its a 2006 4.3 Mercruiser 190HP in a Tahoe Q4. I bought it about a month ago and the warranty is still in the previous owners name I assume. I need to get this changed over. I see this now. Duh! I would consider doing this myself to keep from losing out on using the boat for the holiday and for the next few weeks for that matter. I took off this coming week and had planned to go out on the lake quite a bit. ANY ADVICE WOULD BE GREATLY APPRECIATED!
